TwinTurbo.NET: Nissan 300ZX forum - Did you use Ferrea Dual Valve Springs?
flashstar
on August 11, 2015 at 1:11 AM
Re: Are you sure you didn't overtighten your tensioner?
posted by MaxxAction
on August 10, 2015 at 07:48 PM
Those do carry a much higher spring pressure. I've heard they run around 85 lbs vs 75 lbs for JWTs and 65 lbs on oem springs. Hopefully you didn't sustain much/any valve train damage!
Noise issue with Gates blue timing belt?
Woody75 (Denver)
10:18:51 08/06/15
Pretty common Tim, especially as you described.
ttz'in (norcal)
11:15:43 08/06/15
Awesome, thanks. (n/m)
Woody75 (Denver)
13:46:09 08/06/15
its actually pretty common with Gates belts
diamond20601
00:53:07 08/07/15
Re: Noise issue with Gates blue timing belt?
MaxxAction
10:06:10 08/07/15
Are you saying that upgaded belts damage timing
flashstar
21:44:57 08/07/15
Re: Are you saying that upgaded belts damage timing
MaxxAction
21:00:51 08/09/15
flashstar
12:13:09 08/10/15
MaxxAction
19:48:06 08/10/15
Did you use Ferrea Dual Valve Springs? -
flashstar
01:11:28 08/11/15
Re: Did you use Ferrea Dual Valve Springs?
MaxxAction
09:14:23 08/12/15
